drybreaks?
drybreaks?
For cars that have the female drybreak to allow fueling fast via dumpcans what happens if you don't have a dump can? In a pinch can you fuel the car with just a funnel? Will the funnel push open the female break so you can add fuel?
Thanks I'm clueless
Thanks I'm clueless
Yes - if need be you can initially open the flap with a screwdriver.
A small PVC pipe with an elbow works well for this. Better than a screwdriver as you can pop it in and it holds open while you are fueling. That said, nothing beats a can with a dry break.
I found that using my old Flo-Fast fuel pump system works just fine by wedging the hose into the inlet, held firmly in place by the spring-loaded disc of the inlet. Didn't need to buy the dump can and valve, so saved a few $$, and using stuff I already had.
