02 Sensor alarms w/ Fabspeed X-Pipe
Old 02-01-2019, 03:00 PM
BF951
BF951's Avatar
Default 02 Sensor alarms w/ Fabspeed X-Pipe
I sometimes get an 02 failure warning that I can clear with an OBDII reader. It does not tell me if it’s a sensor upstream or downstream from the CAT. I did replace the upstream sensors, but I believe it’s an issue with sensor being too close to unrestricted air flow. I may just need to add an 02 extender pipe.
Does anyone have experience with this? Which sensor(s) you needed to extend?
TIA
Brian
Old 06-01-2019, 02:31 PM
BF951
BF951's Avatar
Nobody with Sport cats and CEL's ??
Old 06-01-2019, 03:42 PM
Spinout
Spinout's Avatar
The error should state which bank and pre-or post cat. 02 extenders usually solve the issue.
I run Speedtech X pipe with no cats and I’ve never had an issue with O2 errors.
Old 10-09-2019, 06:06 PM
BF951
BF951's Avatar
Anyone with first hand experience using a spacer ?
Quick Reply: 02 Sensor alarms w/ Fabspeed X-Pipe
