Sandwich Adapter Thoughts
I'm looking for a Sandwich adapter to run some sensors for my AIM setup.
I found these but looking for any recommendations or experience with them or similar.
https://www.rallysportdirect.com/par...ndwich-adapter
https://www.glowshiftdirect.com/oil-...mm-1-5-thread/
http://www.deftracing.com/prosport_g...ptor_plate.htm
Hey Now....
I've had less track days cut short than you when you factor in all of those PDK failures.
Blow one AOS and need a 5 hour tow home and they never let you live it down :-)
I've got the glowshift one, but it has 13/16-16 thread (to match the LN Spin on adapter that is not for IMS solution) - I was going to run extra oil pressure and temp sensors there to compare with the sensors in the valve covers, but lost my enthusiasm for the project Do you have a different thread? Yours links seem to go to M20-1.5?
If you need 13/16-16 and want to check my sandwich plate out, it is yours for the price of shipping, and if you want that extra oil temp and pressures senders (VDO 300F and up to 70'ish PSI - same range as stock 996, although I don't now how they would integrate with AIM) we can figure that out too.
It is all new and uninstalled although I did test fit the sensors into the glowshift sandwich.
