F-Stock Boxster Build
#31
Once you take the motor and support out you are left with linear plastic pieces having teeth on it (that was moved by the motor gear).
I just zip tied them to the spoiler bracket. If you push hard, you can move the spoiler and if you remove the zip ties you can move the spoiler up and down manually.
#32
Just spent the weekend at the Season Closer DE with PCA NCR up at NHMS (Loudon).
The new car performed great.
A few comments:
- It's way more fun than my 997 (I hate to say it!)
- I need much practice shifting.
- I need to buy a lot of tires
- The fuel filler vent needs replacement. Very slow flow to fill.
- There's some grease spraying out one of the rear axels at the wheel - hopefully just overpacked.
- Burned through front pads - a PCAer was nice enough to lend me a set of take offs.
- Corded R7s - need more camber
Here's a end of day video on corded (excuse for being so slow) R7 slicks.
A few comments:
#33
A few comments:
https://www.youtube.com/watch?v=Mb-6OIyYtSg
A few comments:
Before replacing the fuel filler vent, try turning the key to the accessory position when fueling. My car will only fill with the key on. Some type of anti-roll over valve. Yours may be the same.
#34
I'm in....
Originally Posted by sbelles
If you mean from the hub, that's probably a wheel bearing failing.
#37
Dave,
The hole in the outside end of the axle is the vent for the outside cv joint. If it is oozing out of the hole it was either over stuffed with grease or the grease just got very hot. I would take a look at the ball bearings and re pack with Neo grease during the long winter months. On the inner CV joint I put a small piece of a WD 40 straw under the clamp so that end can vent. Warning- this is a very messy job so have lots of rags on hand before you beigin.
#38
I currently have cat-less race headers feeding the stock exhaust (with secondary cats).
In an effort to have a more agressive sounding and free-flowing exhaust at some tracks (WGI) but STILL be able to make noise restrictions at LRP and other quiet tracks, any opinions on welding electrically actuated dump valves in the exhaust sections between the secondary cats and the muffler?
Will this result in sufficient backpressure when dump valves are open? Any other comments?
#40
Livery is complete except for orange powder coat wheels which are in process.
Props to Darius of RabidWraps.
www.rabidwraps.com
www.rabidwraps.com
#41
Basic Site Sponsor
Basic Site Sponsor
Received 2,849 Likes
Looks great!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#42
Well, a trip to my indy resulted in a new throttle body and fuel filler vent.
Now the next problem....the battery does not hold a charge.
I only know it is an Interstate new looking battery with a Mfg date of Jan 2018 stamped on the battery.
I'm pretty confident there's no load on the battery since there is a motorsport solenoid disconnect.
After about a week I'm down to just under 25% (according to my NOCO charger); and the battery charges up properly, but it will slowely discharge over about a week.
Before I bought the car I suspect it sat for awhile - perhaps the Jan 2018 battery was left to go completely dead - would this ruin the battery?
#43
AeroCatch; 3D printed brackets.
Been busy installing AeroCatch hold downs on the car. Decided to try to fabricate custom brackets for the pins using 3D printing of NylonX (a Nylon/Carbon Fiber mix that has both strength and high temp tolerance). Here are some pics of the trunk install, followed by the frunk bracket. Moving on to the frunk latch install this holiday weekend.
#44
Love it. Have you designed brackets for the front and would you mind sharing/selling the file?
I desperately want to delete the stupid electronic frunk release with the battery sitting up there...
#45
After the complete install I'll post the files (I suspect I might have to make some adjustments and refab).
