Sub Belt Bar Question
Rennlisters,
I'm getting setup again for the track and am going to use a harness sub belt bar with my Recaro Pole Positions, Have any of you been able to setup the typical Brey Krause bar so the sub belts can be snapped-in instead of wrapping around the bar? Has anyone drilled them and installed an eye bolt or come up with another option as swapping the harnesses/seats in and out when wrapping them will be a pain.
Thanks,
-Skip
Thanks,
-Skip
When swapping, won't the seat/mounts/sub bar and sub strap all go in or out as a single assembly?
An eye bolt atop the sub bar, a clip-in end and a three bar adjuster is a bunch of hardware, length-wise, where you may not have much space... you want the cam lock on the harness to be really low down.
