SOLD: CoolShirt Pro Air & Water System (damaged) $100
SOLD This is a Platinum-Series cooler (15.5" long x 10.5" wide x 13" high) with a new internal 2 amp water pump wired to a 12 volt power supply. In addition to water cooling, you can also have cold filtered air blown directly into your helmet (requires an external 235 CFM blower fan – not included).
This is the cooler box only and it normally retails for $531. I will sell it for just $100, shipped free anywhere in the lower 48. Why so cheap?
When installing a replacement pump, the inner shell of the cooler was cracked. This does not affect the function of the box in any way. However, after use, it must be inverted and thoroughly dried of water that leaks in between the inner and outer shell. A handyman may be able to repair the cracked internal shell.
