where to get this 996 cup car fuel extraction hose
basically a hose/connector that connects to the fuel pump of a 996 cup car to get fuel out of the tank
http://www.parker.com/portal/site/PA...ind+a+Location
Find your local Parker / Hose Doctor location and tell them what you need. They'll have the proper fittings and can crimp it onto an appropriate hose for fuel / gasoline. I've used my local location numerous time for custom hoses.
Your car has either a Sobek or Staubli fitting, so it will not mate properly with anything made by Parker unless you change everything over to Parker fittings. I would first try Ed Baus at Demon Speed Motorsports; he sells a fuel pump-out hose for Cup cars, but I'm not sure what vintage it's for. A picture of the hose he sells is below. You might also check with PMNA; they can probably sell one as well. Note that hose shown in the photo below also shows a Porsche part number (but I'm not sure if it's the correct part number for your car). If you need a Staubli fitting, which was used on some cars, then you need to go through Jack Gilsdorf at Cup Car Solutions. Unfortunately, these parts are stupidly expensive. You might prefer to suck it out through a garden hose!
I commend Ed Baus and support him when I can. But I got mine from PMNA for $108. You can look at Demonspeed's price and choose what you want to do.
Fuel Pump Out Hose: 996.110.355.90
Its a somewhat standard disconnect that a good (not lowes etc) fittings/hose shop can mate up. We have a gigantic place here in Tampa that does every type of air/hydraulic hose and fitting. We built several for like $6 each. One time we couldnt match the male disconnect on one of the cars, so we just got a new male and female. Just screws into the fuel system in back.
Basic Sponsor
We do have a couple of used ones too (that are just fine)
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
