Cold weather balaclava
I'm impartial to the TraqGear products because Roger makes such good stuff. The 2 layer is really comfortable.
https://naroescapemotorsports.com/pr...ies-balaclava/
Heavier is the G-Force double layer and might be a bit warmer.
https://naroescapemotorsports.com/pr...-double-layer/
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
You might look at industrial sources too, although they won't have an SFI/FIA rating. I have a thick nomex balaclava that's designed to keep you warm and safe when working outside on heavy oil/gas machinery. It's always hot here so I've never worn it on track.
Not the question you're asking but if your hands are getting chilled in the open cockpit, put on some purple nitrile gloves under your nomex gloves. Keeps the wind chill down. I realize this is a terrible safety violation but if you NEED to get out and drive open cockpit when it's cold, then,...well you know.
Search for gear aimed at firefighters. Lots of options and fireproof. Some examples
https://www.legionsafety.com/fr-hood...alaclavas.html
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If a significantly thicker balaclava can fit while you are wearing your helmet we need to talk about how poorly your helmet fits the rest of the time.
If wind is getting up under the helmet and calling you, you can get a helmet skirt that is nomex. Common in the drag racing world.
http://www.jegs.com/pt/Helmet+Skirt
As for gloves, if that is an issue. Find a pair that has a higher percentage of leather.
