Turn 1 St Petersburg
The car that tucked in tight on the corner knew the risks..... he drafted his way to the inside for that corner but he didnt "own" the corner. He also couldnt hold that tight of line and as result hit the other car. Had he been able to hold that line, everything would have been fine.
The car on the outside stayed on his line and gave sufficent room. He never really closed the door on the other car but he never gave any additional room for him either.
inside is at fault
at :05 you can see that the rear of the inside car stepped out significantly and he had to full lock counter steer to control it which caused him to slide into the outside car.
Basic Site Sponsor
Basic Site Sponsor
Received 2,833 Likes
Like MarcD147 said. Rossi had lost control of the car going in. Wickens left a car width and maintained control of his car. Rossi did not...\
In this screenshot, you can see that Rossi is FULL STEERING LOCK LEFT, so he was already done. Damn shame he took Wickens out.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
seemed like the inside car understeered badly, maybe being upset by the turtles, even before he reverse locked. just my opin. either way low percentage move....
Not sticking up for Rossi too much, as it was an optimistic move and Wickens clearly deserved the win...but Dixon and (I believe) Rahal also had very similar episodes braking into T1. There was obviously less grip off-line, but apparently the paint markings on the runway were especially slick this year and the new aerokit is much less stable under braking.
Anyhow, my point is that if the Iceman himself messed it up, everyone else gets cut at least a little bit of slack. And it was for the win
I was wondering how long it would take for this thread to appear.
This ain't PCA racing. This is a professional race series. With just a couple of laps to go, Rossi gets a run on Wickens, and HAS to go for the pass. His execution was sloppy but was not a bonsai. I'm sure Rossi would have liked a clean pass and not taken out Wickens, but he couldn't get it done.
I'm sure the roles will be reversed at some point during the season. Wickens knows how to drive in the ultra aggressive DTM series. I think we'll see this guy at the front again.
Basic Site Sponsor
Basic Site Sponsor
Initial glance seems like it's Rossi's fault, however based on Indy rules it seems Wickens actions constituted illegal blocking. His initial move inside was a reaction to Rossi's move, apparently not allowed in Indycar (IIRC in F1 you can change direction once).
It's pretty obvious from the footage alone that the move was a reaction, and this comment makes it pretty clear that Wickens' move wasn't preemptive: he recognized his lack of defense and reacted after Rossi moved, but then backed off in fear of a penalty.
Did you know that IndyCar #u(ked up and DIDN'T TURN THE PACE CAR LIGHTS OFF, to indicate to those behind that they were going into the pits?
NO WONDER THE CONFUSION!
So. Many. More. Things. Wrong. Than just what the video shows...
I also think though that regardless of the circumstances (pace car lights issue etc), it was obvious that Rossi was going to be ahead at the turn in, and Wickens could have left more room on the inside...He (wickens) ‘purposefully squeezed Rossi/defended the the corner (DTM style)’!!! It is just another perspective on it
The car on the inside couldnt hold his line and ended up needing more room and caused the accident.
Perhaps the car on the outside could have given more room (and give up position) to protect himself seeing as it knocked him out of the race completely.
Basic Site Sponsor
Basic Site Sponsor
He gave room and stayed on his line.
Should he have HAD to yield, to avoid being hit? THAT is the real question...
It would seem odd to me that a driver MUST alter his line to accommodate a driver who has lost control of his car. If Rossi was under control and contact occurred I could see an argument.
But if Rossi had control of his car contact wouldn't have occurred and that seems like having done enough.
But once you lose control of your car doing something that can't be done it seems equitable to me that you bear the result of whatever happens next.
Basic Sponsor
Yes, Rossi had to go for the pass, but that doesn't excuse him from fault. He screwed up. He lost control of the car and took Wickens out. He is at fault (look at ProCoach's picture...even through the turn Rossi still did not have position on Wickens).
It's pretty obvious from the footage alone that the move was a reaction, and this comment makes it pretty clear that Wickens' move wasn't preemptive: he recognized his lack of defense and reacted after Rossi moved, but then backed off in fear of a penalty. If he had been proactively driving a defensive line, there would've been no reason to think he was blocking. Doesn't excuse Rossi for running out of grip causing a collision, however Wickens is not absent from fault. Perhaps this is why no penalties were issued.
Wickens left racing room and maintained control, Rossi lost control of his car. I'm disappointed no penalty was issued.
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
