learning to trail brake
#61
Agree totally, but what about slow corners before long straights (Mosport turn 5 or hairpin corner 7 in Portland), reward getting on the power early (at or before the apex), whereby carrying more speed through the apex delays power application until exit?
#63
If the statement above is true, I'm braking too much too late because I'm trailbraking down to the apex. Sounds like I'm braking too deep.
-Mike
#64
So, just to be clear for these tight hairpin corners, enter the turn with as much speed as possible (which is a lot more than most people think), get the braking done early and get back on the power before the apex?
-Mike
-Mike
#65
Each turn at each track is different. Let's be careful to remember this as these ways of taking turns, braking, throttle application, all vary each turn at each track.
And then there is the difference in cars. Each car handles differently on each turn at each track.
I have a 1978 911 stock E class that is very different from my 2010 GT3 gutted race car. The tires r7 vs slicks. The power. The weight. The brake system. The suspension geometry.
And then there is the weather, temperature, humidity, barometer, clouds/sunny, etc.
My point is that the variations of opinions vary as much as all of the above.
To be most helpful discussing braking it would be beneficial to mention what car and what turn and what weather.
Fwiw, I stopped racing my two cars at the same PCA club race weekends because switching back and forth slowed me down. The cars drive so differently. And the approach to the turns is sooooooo different. WGI t1 for example, gt3 trail brake past apex, E full throttle before apex.
#66
-Mike
-Mike
#67
Basic Site Sponsor
Basic Site Sponsor
Received 3,340 Likes
The number one issue is people going too quickly into truly SLOW corners and too slow into FAST corners.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#68
Just my 2 cents, of course!
-mike
#69
Basic Site Sponsor
Basic Site Sponsor
The more I drive the more I realize there's only a few different types of corners out there no matter where I am or what I'm driving. The number of unique corners is pretty small and if you can conquer the common ones you'll be pretty quick anywhere in almost anything (also has a side effect of quickly learning new tracks). As fun as bench racing on the internet is, it's incredibly easy to overanalyze and overthink most things related to driving a car fast.
-mike
-mike
Very often, the light bulb goes on for drivers when they recognize how a new-to-them corner is similar to a familiar-as-an-old-shoe corner, and adopt that type of corner methodology to do the new one better.
#70
-mike
-mike
1. A standard corner would have 3 cones. The point you leave the outside of the track, the apex, and the point you meet the outside of the track again.
2. A double apex needs entry and exit cones like a standard corner, but would have 2 cones for the two apexes so a total of 4 points.
3. A chicane is essentially two standard corners in opposite directions, but the last cone of the first corner is the first cone of the second so it has a total of 5 points.
All these can be linked in sequences as well. For example, the 2nd apex of a double apex might be the 1st apex of a chicane.
A full throttle corner is sort of a 4th type as it's a standard corner that needs no deceleration so the starting and ending cone are not at the edge of the track. Every track in the entire world can be broken down into just these 3 (or 4) types of corners.
#71
-mike
-mike
Just get out there and you'll figure it out; if not, there's always golf
Gary
