One week of Black Friday deals at Demon Speed
Basic Sponsor
At Demon Speed, we do not just sell parts. We also design, build and race our own parts.
Quality and thoughtful design are very important to us and, as we know, to you as well.
We have several new products heading your way that we are in the process of designing and building. These will be ready over the next few months.
While we work away and you wait for the release, we wanted to offer some great savings for Black Friday.
We will be listing new sales exclusively to Rennlist over the next week, but if you would like to join our mailing list so that you do not miss out on any of the new products (like cup bumpers, headers, 996 Cup and GT3 street slotted rotors ...) Then head to our home page for the website and register for our mailing list.
The first offering that we have for this week is CSF Radiators. All of our CSF products are offered at a discount that you must go to the website to see. Use coupon code CSFblack to see your sale price.
http://demonspeedmotorsports.com/sea...c?keywords=csf
These will be the lowest prices we have offered all year.
Ed
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
Basic Sponsor
Second Day of Black Friday.
15% off of Demon Speed selected suspension arm products. No coupon code needed. Sale price is adjusted on the site.
Today we are featuring our own Demon Speed Suspension Arms and parts. We have some great items in this selection and it is an example of Demon Speed manufactured items. As I had mentioned above, Demon Speed does not just resell other manufactures items, we are also the manufacture. The suspension parts were one of our very first items we had made. They have been tried and tested on Porsche GT3 Cup cars of 996 and 997 vintage with positive results. We even manufacture some very simple products like the Control Arm shims which are laser cut and hard coat anodized.
Speaking of this, we not only sell our products, make our own products, but we also race our own products. Demon Speed Motorsports competes in the Stuttgart Cup with the International GT in the Demon Speed/CSF Radiator/Hawk Brake 2008 GT3 Cup. We make an effort to put all of the products that we make and sell to the ultimate road test. Our racing also provides us with ideas of what others would be interested in having since we find ourselves wanting that product as well. We are Racers / Engineers / and Manufacturers who race to bring great products to other like minded Porsche owners.
Listed below are the links to our suspension products for the 996/997/Boxster
The last item on the list is a very unique item. It is the front caliper bolt for the 996 and 997 GT3 and Cup. This replaces the pin and bolt that your remove to change your brake pads. As you know, the front of this pin has just two flats on it to keep it from spinning. Demon Speed has changed the design of this pin to have a hex head on the front. This helps to save your caliper from damage when the bolt is tightened too far or when you struggle to loosen it because the heat and dust from braking has locked it in place. Although the picture is of one, the price is for a pair and come with new flange bolts for the rear.
Ed
http://www.demonspeedmotorsports.com/Rear-Adjustable-Toe-Links-S-RTL6.htm?categoryId=-1
http://www.demonspeedmotorsports.com/Front-Adjustable-Toe-Links-S-FTL6.htm?categoryId=-1
http://www.demonspeedmotorsports.com/Rear-Adjustable-Upper-Links-Dog-Bones-S-RDB6.htm
http://www.demonspeedmotorsports.com/Alignment-Shims-Control-Arms-S-AS.htm?categoryId=-1
http://www.demonspeedmotorsports.com/9971-GT3-Cup-Rear-Adjustable-Toe-Links-S-7TL.htm
http://www.demonspeedmotorsports.com/Locking-Plates-Rear-Toe-S-LP.htm?categoryId=-1
http://www.demonspeedmotorsports.com...?categoryId=-1
Ed
Basic Sponsor
Today's black Friday deal is Tire Warmers.
These have been a great product for Demon Speed. Made to DSM specifications.
Right now, take advantage of our lowest advertised price for tire warmers ever.
We carry in stock a standard size which fit the GT3 Cup cars, but this size will also fit many other applications as well. Send us your tire sizes and we will determine your need. If a non-standard size is needed it is a special ordered.
Benefits of Tire Warmers:
- Set your temperatures hot.
- No need to have a large predictive change between the tire cold and at the end of a session.
- No need to guess a starting pressure based on the current temperature of the tire (how long since the last session) and the ambient temperature.
- Hit the track at speed.
- You can not win the race in the first lap, but you sure can lose it.
- Do not give up precious seconds to the competition who have tire warmers in the first lap.
- Do not run the risk of spinning and ending up in a gravel trap because the cold tires were not up to temp and pressure yet.
- Maximize your time on track. If it takes 2 to 3 laps to bring a cold set of tires up to temperature this can be consuming as much as 25% of your session time. Reclaim your expensive track time and have tires that are at full performance much faster.
- Save heat cycles
- When tires are heated and then cooled the rubber in the tires becomes progressively harder. How much harder and how this affects the performance of the tire depends on the tires, but after a number of heat cycles the tire is no longer as fast as it was earlier in its life. Using tire warmers helps to limit the number of heat cycles when the tire warmers are used between track sessions
Come see the full ad now here:
http://mailchi.mp/608f08dafe1e/black...-deals-1319921
Now includes Demon Speed Center Lock parts, Bilstein PSS Shocks, Hawk Pads and more.
Ed
Ed
