Cayman track cars: Keep or remove rotor backing plates?
Old 09-25-2017, 02:32 PM
User 52121
User 52121's Avatar
Default Cayman track cars: Keep or remove rotor backing plates?
So I've heard compelling arguments from both sides. What say you?
I suppose the question could apply to either front OR rear but in my case, I'm curious about rears - especially given the tendency to cook rear brakes on these cars.
Are you running the factory backing plates, or did you remove them?
One side says: need as much airflow to the rotor as possible
The other side says: the sensors and wiring in/near the spindle will cook without the plate there to deflect the heat
Thoughts?
My car does NOT have them on the rears right now (I do have them on the front.) Car came (to me) that way. I'm leaning towards finding a set and reinstalling as I tend to trust the opinion of "the other side" above a little more.
Old 09-25-2017, 04:15 PM
HoBoJoe
HoBoJoe's Avatar
Jim, I can't help with your specific question but make sure you grab a set of GT3 front brake ducts and 997 Turbo rear ducts from your local dealer. The 997 turbo ducts will need modification to fit.
Old 09-25-2017, 04:22 PM
User 52121
User 52121's Avatar
Yup ahead of you there. Suncoast (or Sunset?) had the GT3 front ducts for *under* $4/ea. The 997TT rears were ~$20/ea.
Installed those 2 weekends ago.
Old 09-25-2017, 05:28 PM
jscott82
jscott82's Avatar
Interested to see where this goes... I may be starting down the SPC slope this winter...
For the 993 there was a factory solution to cut the plates down to the bare min.
https://rennlist.com/forums/showthre...ferrerid=45114
Old 09-25-2017, 05:51 PM
User 52121
User 52121's Avatar
For the 993 there was a factory solution top cut the plates down to the bare min.
Innnnnnnnteresting. Good find!
Old 09-25-2017, 06:33 PM
multi21
multi21's Avatar
Received 2,952 Likes on 1,747 Posts
do you happen to have the part #s to these? I tried both sun coast and sunset Porsche, but didn't come up. Thanks.
Old 09-25-2017, 07:20 PM
Bill Lehman
Bill Lehman's Avatar
If permitted, ditch the front brake shield and add the Olsen Motorsports brake ducts. Here's some pics of the TT modded rear brake ducts.
Old 09-26-2017, 12:36 AM
certz
certz's Avatar
jscott - let me or Matt Distephano (RL - jdistefa) know if you decide to build/buy an SPC. We have an email thread going of most of the SPC drivers so we can ask questions, etc. The SPC group is very supportive and helpful with setup, build and anything else you might need.
The OP already knows my thoughts and I had big problems with overheating of the rear brakes at Road America - I am trying a couple of things for the next race, but always interested in others thoughts. The Interseries cars had a solution, I have seen the turbo duct solution Bill has posted and I have installed modified GT4 rear ducts to try at my next race (I also have the Tim Olsen front ducts).
Old 09-26-2017, 01:23 AM
nxfedlt1
nxfedlt1's Avatar
remove the backing plates.
Olson has a great set up for the fronts, and thanks for info on the TT ducts for the rear!
Old 09-26-2017, 09:18 AM
dgmark
dgmark's Avatar
Modified GT4 duct
Old 09-26-2017, 12:34 PM
User 52121
User 52121's Avatar
$17.96/ea:
997-331-487-02
997-331-488-02
$3.57/ea:
997-341-484-92
997-341-483-92
Via Sunset.
Old 09-26-2017, 01:11 PM
User 52121
User 52121's Avatar
Originally Posted by dgmark
Modified GT4 duct
I think Mark's solution is going to be the most effective. 1st we know the factory feels it's good (on the 981 platform anyways). 2nd, looking at how the ducts line up, they'll be pulling the air that exits the undertrays. Should flow plenty.
Pricing is steep compared to the TT ducts though. Not *awful* but not under 20 bucks either. I may see how things fare on my car with the TT ducts after I fix the PSM intervention first, see if I still get a cooked rear brake issue, before spending the money on the GT4 option.
I'll also be listening closely to John's feedback (owner of the car Mark posted pictures of) to see if his braking problems were completely resolved, better, just OK, etc.
As for the backing plates themselves... seems we still haven't found much in the way of a consensus.
Old 09-26-2017, 01:27 PM
User 52121
User 52121's Avatar
Those are different from the TT ducts I have.
Yours must be 996TT, I'm pretty certain the ones I bought are 997TT.
Old 09-26-2017, 02:28 PM
dgmark
dgmark's Avatar
I'm betting in them melting and catching on fire.
Old 09-26-2017, 03:05 PM
User 52121
User 52121's Avatar
In4video.
Quick Reply: Cayman track cars: Keep or remove rotor backing plates?
