CGT recall?
Old 06-28-2005 | 06:55 PM
Pierre's Avatar
Pierre
Default CGT recall?
My mechanic just told me they have a CGT in because of a recall. He wasn't sure about the reason, but it has to do with some electrical part on the front. Anybody knows about that? If not, I could try to get more details...
Greetings,
--Pierre
Old 06-28-2005 | 10:19 PM
W8MM's Avatar
W8MM
Originally Posted by Pierre
... I could try to get more details...
Please do.
I've heard nothing about it.
Old 06-29-2005 | 03:00 PM
phaedrus242's Avatar
phaedrus242
As of 6/20/05 no recalls or service actions out for the GT.
Old 06-30-2005 | 04:57 AM
Pierre's Avatar
Pierre
'My' chief-mechanic just told me there are actually 4 recalls. Here's the summary:
- change some fuel pipe
- install different cables for the door closing mecanism
- change some electrical connection of the front lights
- add some ventilation to the front lights (many CGT owners reported humidity in the lights)
So nothing really safety-related.
My dealer currently has a CGT in for these fixes. The car is a european version MY '04 (built in June '04 I think).
Greetings,
--Pierre
Old 06-30-2005 | 10:06 AM
W8MM's Avatar
W8MM
My dealer currently has a CGT in for these fixes. The car is a European version MY '04 (built in June '04 I think).
Pierre,
My dealer is pretty good about keeping abreast of things like this. I speculate that the reason I've heard nothing is that my build date (January '05) already included these fixes.
Maybe?
Old 06-30-2005 | 10:45 AM
Pierre's Avatar
Pierre
Mike, you're correct: MY '05 cars might already have these fixes. Asking your dealer about the specific points I mentionned wouldn't hurt though.
Enjoy it!
Greetings
--Pierre
Old 07-02-2005 | 05:24 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Does anyone know the contents of the clutch TSB for MY04? Apparently there is also short shift kit TSB for MY05?
Old 08-23-2005 | 12:42 PM
GoFastKindaGuy's Avatar
GoFastKindaGuy
I just received a recall notice on my '04 (my first) to:
1) modify ventilation of the headlights to prevent fogging and
2) install new cables for easier inside opening of the doors.
Old 08-23-2005 | 06:40 PM
phaedrus242
The dealer will also give you a complimentary detail in addition to the service as dictated by Porsche.
Old 08-23-2005 | 08:35 PM
Sloth's Avatar
Sloth
Just what every CGT needs... the dealership gofor scrubbing it down with dirty water and deck brush.
Old 08-24-2005 | 03:43 AM
20C4S's Avatar
20C4S
no recall on the 05 yet.
Old 08-27-2005 | 05:50 PM
PTEC's Avatar
PTEC
Ok these are service actions.... which are not recalls. These are voluntary measures taken by Porsche to improve the vehicle. So they take it upon themselves to alert you to the issue instead of you figuring it out yourself and having to bring it in. Recalls are federally mandated and are required by the government and they usually deal with safety items. Service actions are totally different. With that out of the way, heres the brake down.
W504. This is installing a new piece of tubing over a fuel line to prevent the corrosion protection coating from being damaged.
w534. Possibility of a loose connection between wiring harness and headlight which could cause the lights to flicker.
w536. Installing new headlight ventilation to prevent moisture from forming in the headlights.
w537. Possibility of high effort required to work inner door release. Cable is adjusted and lubed.
Quick Reply: CGT recall?
