Porsche 959, abs light on, brake hard to press
Old 04-08-2021 | 01:10 PM
Dwad's Avatar
Dwad
Default Porsche 959, abs light on, brake hard to press
Hi guys,
i am currently working on a 959, 87.... So if we press the brake pedal it is too much hard, now we tried to carry out bleeding process( manually pressing ), so there is very less fluid coming out of front brake lines at caliper...
brakes are not ok even if we drive the car, brake pedal goes hardly down..
During the bleeding process I pressed the brake pedal 3-4 time & after that if I open the brake line in rear, brake fluid comes out, this side it is ok ..in the front side it comes. Very slowly & brake pedal does not goes down even if I open the connection to front calipers , brake pedal does not goes complete down......
Now it is complicated system to work on, I am hoping that someone has worked on this car earlier...
Thanks guys ....
Old 05-21-2021 | 09:06 AM
SUPERCARNUT's Avatar
SUPERCARNUT
2nd Gear
Originally Posted by Dwad
Hi guys,
Thanks guys ....
Hi Dwad
Are you any further with this? I have the same issue with a car here, The ABS light on brake pedal very hard and no servo, also have the drive select lights on and the main one flashing, The lights are very dim compared to them on the other side of the dash
Regards
Old 05-30-2021 | 06:19 AM
Dwad's Avatar
Dwad
Originally Posted by SUPERCARNUT
Hi Dwad
Regards
No sir, we left the car as it is..
Quick Reply: Porsche 959, abs light on, brake hard to press
