CGT Transmission Fluid is $1086 per bottle?!?
I’m about to have a major service done on my CGT and the quote includes 4 units of manual transmission fluid @ $1086.44 ea for a total of $4345.76. What is that stuff made of? Unicorn blood?
Leadfoot01 (09-01-2020)
you might want to recheck that
on my last service synthetic 75W90W gear oil was 5@ 9.95 a unit.. about 50 bucks
gear box filter was pricey.. $250
who are you using?
who are you using?
From you manual Page 183: 4.3 Quarts Mobilube 1SHG
Time to find a new dealer for service.. if they can tell you this BS then...
we would like to know who this dealer is?
There's nothing special about this. And it's not like our transmission will disintegrate if we put in a different oil of the same grade.
I'd be hard pressed to think the Mobil Delvac product we put into 996/997 GT3 street cars (and which remain in competition service with all Carrera Cups in the 991) aren't at least as good as the period offering in terms of additives.
My wrench would know better than to bill $4k for gear oil when mine goes to service. I'd promise him a Pacino / Scarface moment...
I just had a major at my local Porsche dealer. 4 quarts of transmission oil was $209. Are you sure about your $4k quote just for fluid??
Here’s the quote from Suncoast. Also checked other dealers online—cheapest I found was $925 per unit. So my thoughts were exactly what all of you posted—is there an appropriate substitute? Service bill will be $23K with this fluid—$19K and change would be a nice alternative. The car deserves OEM parts of course, but transmission fluid seems to be something that reputable companies can source at comparable, if not better, quality/performance metrics.
Basic Sponsor
It looks like you must have been quoted for a quantity of 4 - 20 Liter containers of the fluid.
The proper part number is:
000.043.305.49
Priced around $35 a liter online and here at the dealer we charge $45. A drain and fill procedure during a service only requires 3 Liters, only reason more would be needed is if you were draining the transmission oil cooler and lines separately.
Also, there is no replaceable transmission filter
000.043.305.49
The Standard In Porsche GT Service
(203)257-0987
Info@RepasiMotorwerks.com
www.RepasiMotorwerks.com
(203)257-0987
000.043.305.49
Priced around $35 a liter online and here at the dealer we charge $45 a drain and fill procedure during a service only requires 3 Liters, only reason for more would be if you were draining the transmission oil cooler and lines separately
000.043.305.49
So your Porsche dealer doesn't know the difference between 20 Liters and 1 Liter? Is that the case?
GT3 player par excellence
Basic Sponsor
