Why don't any feel any difference between different PASM settings?
On my 23 Macan S, I feel zero difference between standard, sport and sport plus setting of the PASM. Is mine broken or is it something super fancy/secret what only the experts can feel when they take the Macan to the track?
If you go from Sport to Sport+, you should see a drop from gear 7 to 5 and an increase of rpm.
On a smooth road, nothing will happen in terms of ride quality. At a normal driving pace, nothing will change.
You can notice it on really bad roads, but more than anything it comes into play at 9/10th's and above, which basically never happens on public roads.
mrcarlo (01-17-2024)
My town (Irvine in OC) has pretty smooth road surface and I don't notice much different as well but when I go to LA (pretty nasty road condition), I notice difference. Macan PASM isn't like dramatic changes in 911 but it's def. different between settings. So if you don't notice much, you should be happy that you live in good area to drive Macan. =)
take a corner on each mode, you will feel a difference. don't over do it -- it's an suv after all.
If you've ever driven on a track you should be able to tell when it's on normal, sport, sport+ suspension.
You can also take a speedbump, but you will risk damaging the suspension if you're just barrelling down the road.
ehanauer (05-21-2024)
With air suspension it's definitely noticeable, but it's subtle. The ride quality on the air suspension is absolutely perfect, IMO... absorbs bumps without muting road feel... not sure how they did it, actually. What you should notice between settings is less side to side roll, less front end dive under braking and less squat under acceleration.
I am getting the 2025 Macan GTS, loaded. My salesman at the Porsche Dealership let me drive his GTS. I noted the same thing. His response, this is not a 911.
There must be something off. The GTS has an air suspension standard, the S not. Mine has steel suspensions with PASM and it seem to be normal that you don't feel anything. With the air suspension you definitely should feel something, I mean your height is changing when you change the settings and this should definitely be felt when you drive.....
I also have a '23 S, but mine is on the air suspension. The difference between normal and sport is subtle, but noticeable. Sport + is significantly firmer than sport, but still very compliant. I test drove one on steel springs and the difference wasn't as profound, but I could feel a difference between all three settings.
