Macan 2014-Current
USB ports in 2020 base macan
Old 02-22-2020, 03:06 PM
jackporsche09
jackporsche09's Avatar
Default USB ports in 2020 base macan
the 4 ports in the vehicle are smaller than the ports in my 991.2 and therefore cannot be used with my thumb drive or my Samsung phone the charging plug for the phone appears to be the same in physical size but will not fit into the usb I assume that I will need some sort of adapter can anyone out there straighten me out in this Thanks
Old 02-22-2020, 03:20 PM
Marc-911
Marc-911's Avatar
The USB ports in the 2020 model are USB-C type (the smaller ones) not the regular sized USB-A ports.
Amazon has these for around $8
http://www.amazon.com/Thunderbolt-Compatible-Chromebook-Pixelbook-Microsoft/dp/B07KR45LJW/ref=asc_df_B07KR45LJW/?tag=hyprod-20&linkCode=df0&hvadid=312780390407&hvpos=&hvnetw=g&hvrand=15385269070327280372&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027821&hvtargid=pla-636721944170&psc=1 http://www.amazon.com/Thunderbolt-Compatible-Chromebook-Pixelbook-Microsoft/dp/B07KR45LJW/ref=asc_df_B07KR45LJW/?tag=hyprod-20&linkCode=df0&hvadid=312780390407&hvpos=&hvnetw=g&hvrand=15385269070327280372&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027821&hvtargid=pla-636721944170&psc=1
Old 02-22-2020, 03:57 PM
jackporsche09
thank you Marc for your prompt reply
Old 02-23-2020, 12:48 PM
Spyerx
Spyerx's Avatar
Received 1,790 Likes on 1,089 Posts
Yep, you need an adapter or new cables.
Amazon Amazon
Old 02-23-2020, 10:22 PM
Pavegeno928
Pavegeno928's Avatar
My 2019 takes the standard USBs. Odd they would change that fro the 20199 to the 2020.
What is the advantage of the USB-C?
Old 02-24-2020, 06:56 AM
OliverK68
OliverK68's Avatar
Smaller connector, reversible, handles more current, and faster bit rates
Old 02-24-2020, 10:35 AM
BOPE
BOPE's Avatar
This was comprehensively answered by OliverK68, but in my mind the BIG advantage of the USB C is the reversibility.
Jason
Old 02-24-2020, 02:41 PM
OliverK68
OliverK68's Avatar
Jason
Indeed.
New iPads use USB-C, and the supplied cable has the same connector at both ends so it matters not which end you grab and which way you plug it in.
Old 02-24-2020, 03:24 PM
Pavegeno928
Originally Posted by OliverK68
Indeed.
Wait, that doesn't sound like an improvement. I throughly enjoy plugging in my traditional USB only to find I have installed it the wrong way. Then I reverse it and it still doesn't go in. Then I reverse it back to the original and it plugs in easily.
Don't take that satisfaction and joy from me knowing I prove the law of odds wrong every time I try. I must be very special.
The following 2 users liked this post by Pavegeno928:
ITgr1 (12-01-2020), tk-porsche (02-24-2020)
Old 02-24-2020, 06:19 PM
jackporsche09
thanks everyone pu a C adapter at Best Buy for under $10 situation resolved
Old 02-24-2020, 06:52 PM
cometguy
cometguy's Avatar
Are there still 12-volt plugs in the 2020 models? If so, you can buy an adaptor that plugs into the 12-volt plug that has two standard USB ports -- I have that in my car because I don't want to open the armrest to get at the USB ports there. (Attached is a photo showing the adaptor in my 2018 Panamera, which came with the smoking package by accident.)
Old 02-24-2020, 07:24 PM
tk-porsche
tk-porsche's Avatar
Something like this should work nicely, is inexpensive, and doesn't add any dangling wires (sorry, needed to update this with the correct link):
Amazon Amazon
Quick Reply: USB ports in 2020 base macan
