Introducing the Flat 6 Motorsports Macan Intake System!
Basic Sponsor
Hey guys, we're proud to announce our intake solutions for the Porsche Macan (all trims). We designed the system to be modular and also a direct bolt on. It's a very simple install and will improve turbo response and power output. The air filters will be shipped by 9/18 and ETA on the carbon ducts is 10/1. We also have the Cobb maps and dynos we will share. Scheduled for 10/14 at the dyno and will provide plots with/without tuning. Go ahead and take full advantage of the pre-order sale. The promo pricing runs through 9/30!
Macan High Flow Air Filters
Promo Code: MFPREA (1 Filter) MFPREA 2 (2 Filters)
Macan High Flow Carbon Fiber Ducts
Promo Code: MFPREC
Macan High Flow Intake System
Promo Code: MFPRE (S / GTS / Turbo) MFPRE1 (2.0L / Diesel)
Promo Code: MFPREC
Flat 6 Motorsports
Porsche Aftermarket Specialists
www.flat6motorsports.com
Instagram / Facebook / YouTube
Flat 6 Motorsports
Basic Sponsor
It improves power output even without a tune to take advantage of the reduced restriction?
I was under the impression the ECM would just lower the boost to make up for less restriction.
I have 3 inch catless Downpipes on my macan turbo but i know they dont add anything other then sound for the time being without a tune taking advantage of the reduced restriction.
Basic Sponsor
Basic Sponsor
Let us know if we can help. We've got a lot of experience in doing custom Macan tunes. What DPs are you running?
Basic Sponsor
Will get all the dynos up hopefully later tonight. We had a Macan Turbo on the dyno (Mustang Dyno) this weekend and wanted to quickly share the numbers.
Stock vs Stock w/ Flat 6 Motorsports Intakes
Filters/Intakes: +10whp +1 ft/lb
Compared to the Cobb Stage 1 OTS Map:
w/ Stage 1+ Map: +16whp +31ft/lb
We picked up another 14 ft/lb of tq with a conservative pro tune, but the owner had less than 2K miles on his Macan and after all the pulls, had some heatsoak, so playing it safe for some time!
We took the absolute best basline numbers we recorded. I'll get a video together as well, but a couple pics:
With the air filters: a nice gain across the entire rev range.
Basic Sponsor
Here's the plot and numbers for the Stage 1+ Power Kit (Intake System + Stage 1+ Optimized Map) compared to the Cobb Stage 1 OTS map.
Note - the plot had a little more smoothing on it, the picture of the numbers was with smoothing of 1. It has a nice 25whp gain down low as boost is building.
Here it is all together.
Stock
Cobb OTS Stage 1
Flat 6 Motorsports Stage 1+ w/ Intakes
Those are considerable gains throughout the rev range. For only about 400 rpms do we not show a material gain.
Stock
Cobb OTS Stage 1
Basic Sponsor
