Grinding Noise
Turbo-machinery is designed to avoid placing resonant frequencies in their operating range, but not necessarily while spooling up. Low-speed resonances are especially noticeable in airplanes powered by CFM-56 engines (e.g., 737s). Possible in a turbocharger? Dunno. Might it resemble a grinding noise? Dunno, but the CFM-56 resonance is a bit like grinding.
Well, I've been able to isolate my noise to the operAtion of A/C. If on, mechical groaning whining noise between 1200-1800 rpm with vibration and gritty feeling coming through pedal. Turn off hvac system and goes away immediately. Tech rode with me and confirmed noise, also confirmed a/c has magnetic clutch that engages and becomes parisidic to engine. They worked on it for a few hours, then came back to me and said this is "normal" operation. I called BS on them, this car is way to polished and can't imagine Porsche allowing such a design flaw. I've never driven any car $20k-$100k+ that exhibits this, major oversight on Porsche's part if true. Unfortunately no other Turbos on the lot to drive and compare to see if true. They will be picking the car up and keep it for a few days to further diagnos so we'll see.
Question then, if this is normal operation does everyone experience this? Not a pleasant NVH noise but maybe I'm just super sensitive
I also have a vibration somewhere around 1200-1600 RPMs when the A/C is on. 2017 GTS. Took it to the dealer a few months ago. "Normal operation". Annoying, but I'm trying not to let it drive me crazy.
Received 1,543 Likes
I find that when I put our Turbo in Sport mode it keeps the revs sufficiently high that the noise and vibration go away.
It's not normal, and I've never heard any such noise even when set to "AC Max" on my GTS.
Any new info? I feel like the sound is worse now. Really annoying but easily solved by not opening windows. Curious if isolated to gts. To be clear, no steering wheel vibration. Just a slight grinding noise when throttle initially pushed and when let off.
I can feel it periodically in the accelerator and the steering. What the tech is stating would make sense since the compressor cuts on & off. That said, I have tried turning the a/c off when the grinding is occurring but it makes no difference - it's still there. So in my case, I don't think it's the a/c.
