Lightweight batteries
voltphreaks vph-900. 7 lbs and has the ability to shut oitself off when voltage drops below 12 volts. hit the buttopn battery recharges and allows the car to start to continue to charge the battery. not cheap but very well made great customer service and the battery can be sent in for repair if it fails to charge
I use this odyssey and bought a second I keep in the trailer or tow rig.
Here is the website that details all their batteries
http://www.odysseybattery.com/extrem...ery_specs.aspx
Voltphreaks website notes an incompatibility problem with Porsche GT3s which charge at less than 12.5 volts and therefore won't charge the battery. Anybody have such an issue?
One more question. I have the electric steering pump up front which runs all the time when the main switch is on. When the car is running, is the alternator creating enough current so that there is no drain on the battery? I assume so but what do I know. So is the lithium battery compatible with the electric steering pump setup?
I have had a Voltphreaks VPR-P6 since 2012 with zero issues. I ran it first in my 997.2 GT3 and for the last three seasons in my 997.2 Cup. Low voltage cutoff is great and only weighs 6 pounds.
I have a Porsche Motorsports lithium battery that I believe was an option on the 991 GT3 RS. It's standard size so no funky mounts required. My plans have changed and I need to sell it. It's brand new never even test fit in a car. I have all the factory manuals. I believe it's $3200 from a Porsche dealer. I'm willing to let it go for less than half that amount. PM if interested. Thanks JBO
