996 Cup brake failure
Loving my 2004 Cup but on my second outing I suffered a brake failure which my team has not been able to explain.
The car had fairly recently revised calipers and before the day had its nipples replaced. Discs were good though pads below 50%. Brand new ferodo brake fluid. After lapping without issues for about two hours at a fairly high pace with lots of breaks, my pedal dropped straight to the floor in a 200kph-80kph brake zone. As I was closely following a friend in a 996cup, I had no chance to let the pedal come up and try again, instead deciding to steer as far away as possible from my friend (the video from his car shows how close we came to colliding, but amazingly we both walked away without real damage). As this has never happened to me in 15 years of tracking and racing, I was very anxious to find the root cause.
The team checked:
*no air in the hoses
*brake fluid new so could not really be cause of brake fade
*RS29 pads were less than half, so perhaps they did overheat
*discs are drilled OEM ones and weren't yet cracking
They reckon I may have run a curb too hard which could have pushed the pads away from the discs.
Has anyone had a similar experience which was subsequently explained? Or advice how to avoid this from happening again?
The team checked:
It sure looks like boiled fluid to me. New fluid isn't immune and after two hours and chasing your friend at close quarters, brakes can get too hot. I assume you couldn't find leaking fluid and the reservoir was still full. I'd be shocked not to find some bubbles in the calipers.
The head mechanic at my local Porsche garage suggested the same, whereas the team that maintain the car dismissed that.
After just fitting new pads I did run a 1h race with the car and it was faultless. Will follow your suggestion though, as I want to rule out a repeat.
I had a catastrophic brake failure on my Gen2 996 brakes. Pad wear can be grossly uneven so you think you've got lots of pad left but, in my situation, the unseen portion of the pad was excessively worn and the puck fell off the piston and my pedal went to the floor.
Thanks for sharing that. Pad wear may have played a role here, so that is definitely something I will keep an eye on.
I've been racing a 996cup for a while. Here's my feedback:
Worn out pistons, MC, or brake booster typically feel pretty similar. Pedal doesn't go to the floor, just feels soft and gets softer through the brake zone.
With knock back your pistons are merely retracted into the caliper slightly, so the pedal engages just a bit deeper than usual then it feels firm.
Your situation sounds like textbook boiling. I've run PFC 01 down to the backing plate with no boiling using Castrol SRF. Historically that's the only fluid the pro teams use. Lots of companies like to quote dry boiling point, that **** is irrelevant. Once you crack that bottle open and pour it into the reservoir that fluid is absorbing water by the minute, so only look at the wet boiling point. Assuming you're using Ferodo "formula" thats a full 100 degrees F lower wet boiling point than Castrol SRF. Also when you say fresh fluid... we typically bleed the brakes every day of the race.
Bumpy brake zone with low hard pedal and no braking power.
Hard to do in the heat of the moment, but get off the pedal and reapply. Different than pad knock back, and will behave normally after cycled.
Early cups can have this issue.
Thanks for all the input!
In my case the pedal went straight to the floor, rather than getting soft or increased travel. So reading through all the comments and advice from others, boiling fluid seems the be absolutely the most likely cause, probably triggered by fairly worn pads. Whilst I am personally not very technical and need advice from experts, it surprises me a little that the team (that have been running the car for the previous owner and now me for three years) are a bit dismissive of that possibility. In any case, not running the pads till the end and using better brake fluid will certainly not do any harm. So that is the route I will follow.
