Small pit in cylinder head. Not FOD
996 GT3 Cup. Looks like a casting flaw. How the &^%^ does this get past quality control?
I'm concerned about it being a potential detonation spot although everything looks fine around it, and there is no mark on the piston that suggests FOD.
![](https://forums.pelicanparts.com/uploads26/IMG_35981498073744.JPG)
![](https://forums.pelicanparts.com/uploads26/IMG_35961498073744.JPG)
![](https://forums.pelicanparts.com/uploads26/IMG_35971498073744.JPG)
Do I need to fix this?
Yeah that looks like a casting issue. You can have it filled(welded) shouldn't be a big deal. if in any other spot it wouldn't worry but with it that close to the valve seat it could lead to a hot spot and a burned seat. Its an intake valve so not as bad as an exhaust, but while you have it apart....
