In very good condition...couple plastic location pins snapped off...some small superficial scuffs .
one fender flare looks unused....red tape still on the adhesive.
located in the UK so postage a cost consideration if the buyer in the US. I don't have much in these so pointless me selling cheap to lose out on shipping.
400USD plus shipping which will be 50 to 75 usd....UPS.
thanks
You either trim your existing fender and mount the flare to it, or have the lip on the flare ground down so u can just attach it to your existing fender. Obv the differences in doing this would be the amount of clearance you have.
Or the third choice is get the cup fenders as well, then you have your stock fenders preserved.
If you wanted to go with Cup Fenders as well, here are the part numbers and costs from FVD
997 503 931 96 Fender Left 997 GT3 Cup 10-997$494.93
997 503 932 96 Fender Right 997 GT3 Cup 10-99750393296$531.53
Here is an example of cutting the stock fender:
And here is my GT3 with the Cup fender, as you can see the opening of these fenders is significantly larger than stock fenders to allow a wider front tire to fit under the flare.
