6.1 Cup Rotor Recommendations
Any recommendations for front rotors for 6.1 cup with 5-lug hubs? I tried the Cayenne 330mm but they had what looked like lug holes instead of screw holes to attach to the hub. The only other rotors I've been able to find are Girodisk and OEM drilled.
They only have the 350mm on their website but I'll call them on Monday and see if thy have them.
It is not horrible to not use the screws to attach them to the rotors. A bit more fooling around to get everything attached. The wheel and the lugs are what really hold the rotors in place, those screws are just to hold them during assembly.
I have used those Cayenne rotors without using the screws with no issues.
Ed
Also, you can have the holes drilled and countersunk on the rotors as well if you really want the screws.
Ed
That's really good info. I was wondering if there might be a trick to it.
Basic Sponsor
If you have a 996 Cup or GT3, our rotors are bolt on and perfect.
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Thanks for responding Rick. I have a 996.1 Cup upright with a 4 pot caliper, hence the need for the 330mm rotor unless I move to spacers for the calipers. If I understand correctly.
