Camshafts
GCS sells CUP S camshafts and i also think there is a possiblity to regrind 07-09 cams to 2010 spec
i think the lift is
07-09 11,1mm
10-12 12,0mm
i think the lift is
07-09 11,1mm
10-12 12,0mm
Memory serves correctly, the 997.1 uses the intake cam the same as the cup s, the 997.2 uses the exhaust cam same as the cup s.
So, the intake from the early 997 and the exhaust from the late 997 are the same as the cup S.
Ed
Ed
i have found a set from a street car super cheap, looking in to se if i could get them adapted to my super duper hybrid projekt
Problem is the street 3,8 gt3 have variocam so need to find out if i could maschine the camshaft to fit regular cam sprockets
