Need Help Updating Bosch MS3.1 ECU
Bought a PMNA 3.8 engine from one of the vendors here last year for installation in a teammate's 2008 (3.6) car... Vendor gave me a .hex file to flash the recipient car's ECU with, but i'm getting stuck with a MODAS error...
Modas > Action > Datapart > Download to ECU gets me this dialog box:
"Datafile not loaded! EPK identifier of data file doesn't match the compatibility"
Is there a specific sequence to follow before I can flash? I've flashed my own car before and all was okay, never saw an error like this...
My MODAS has the 2008_S CFV file loaded (which should match the hardware of the recipient ECU). The hex map I'm trying to flash is 38P3CCP8.HEX, as provided by the vendor. Could I be in need of a different set of files?
I have tried my vendor in earnest but there's no response for reasons right or wrong... any help will be greatly appreciated!!!
I would try to put the 3.8 files in your modas before flashing.
I have had my 3.6 ECU flashed to 3.8 map by PM Germany, and they sent me the 3.8 modas files.
As they made it for free, I haven't tried myself to flash the ECU, but will try within the next few weeks to my spare ECU.
Send me an email if you need them.
Many thanks for the help... gonna try make it work...
Bought a PMNA 3.8 engine from one of the vendors here last year for installation in a teammate's 2008 (3.6) car... Vendor gave me a .hex file to flash the recipient car's ECU with, but i'm getting stuck with a MODAS error... Modas > Action > Datapart > Download to ECU gets me this dialog box: "Datafile not loaded! EPK identifier of data file doesn't match the compatibility" Is there a specific sequence to follow before I can flash? I've flashed my own car before and all was okay, never saw an error like this... My MODAS has the 2008_S CFV file loaded (which should match the hardware of the recipient ECU). The hex map I'm trying to flash is 38P3CCP8.HEX, as provided by the vendor. Could I be in need of a different set of files? I have tried my vendor in earnest but there's no response for reasons right or wrong... any help will be greatly appreciated!!!
