996 Cup Clutch Recommendation
Our "rescue" 996 Cup needs a new clutch disc, pressure plate, and release bearing. Does anyone have recommendations about replacement parts? OEM or aftermarket? Thanks,
Tom
Tom
I have the 5.5 Tilton in mine...It is awesome once you are on track and moving...Revs are instantaneous and super responsive...Shifts like a dream. You will hate it in the paddock and when moving the car around.
The benefit of the 5.5 Tilton is as mentioned above, instantaneous hookup. The Motorsports 4-puck setup is pretty darn close in performance and will self destruct in the event of a significant overrev. The Tilton won't blow until your motor's scrambled, the 4-puck OEM around 9k IIRC and could save your motor....
I have 5.5 triple plate on my car also... Here's another point, if you are extremely good at heel-toe then I would so go for it. If not, I would he hesitant. Rev's drop VERY quickly from high rpm, and you'll be beating the heck out of your power train. Basically about 1/4" pedal travel from full dis-engagement to engagement. There is ZERO slip at speed. I have wheel speed monitors and can see instantaneous rear wheel speed drops on less than idea downshifts. You also need an adjustable pedal stop (do not know cup's have those) or you can push throw-bearing completely through clutch and destroy it (or worst damage motor/flywheel).
