MSA-11BOX
Basic Sponsor
Hello
Sounds like you are new to the Cup Car game.
The gear potentiometer voltage can be set up by reading the voltage directly from your Motec dash as long as you have it set up to show on the display. The 2009 is set at 3.85 volts in 6th gear. If case you have not heard the original gearpots are very unreliable, especially the newer ones. KMP has made a totally new sensor that may be used with much more reliability.
Rodger@orbitracing.com
