Michelin slicks
Michelin slicks
Trying out michelin slicks on my 997 gt2 for the first time in an upcoming time attack track event. I would like to know if anyone had ever tried michelin slicks before and what things should i look for/change in terms of alignment, compression rebound etc.
I usually run the below settings on hoosier r6:
Fr Rr
Camber -3.0 -3.0
Toe -0.07 per side -0.14 per side
Should i stick to the same settings or should i change them ?
I'm running 997.2 cup tires N2. The car has ohlins 2 way suspension.
Fr Rr
Camber -3.0 -3.0
Current setup should be fine, enjoy!
I prefer the Hoosier for longevity, Michelin has turned into very quick tire but disappears on you after 20-30 minutes into front push.
Pirelli is the best currently with good grip, longevity and will come back to you if you ease up a bit after you overcook them....
thanks
Former Vendor
Fr Rr
Camber -3.0 -3.0
Fr Rr
Camber -3.0 -3.0
Fr Rr
Camber -3.0 -3.0
Fr Rr
Camber -3.0 -3.0
