Porsche Cup Cars
Sponsored by: Race Cars For You
Changing from a 997.1 to .2 decklid
Old 12-16-2014 | 03:10 PM
911racer's Avatar
911racer
Default Changing from a 997.1 to .2 decklid
So, I am in the process of adding a 997.2 decklid to my 2008. Doing it for better airflow to the engine.
Everything is going great. Except on the 2008 there is a pressure sensor on the side of the intake (between the decklid and the throttle body)
The 997.2 does not seem to have this. I do not even see in the manual that this sensor exists ?
What is the purpose and where should I mount it.
Ed
Old 12-19-2014 | 12:26 PM
Stratair's Avatar
Stratair
Can anyone help?
Old 12-19-2014 | 02:34 PM
McRae's Avatar
McRae
It measures ambient air pressures for correct ECU fuel/ignition calculations. On the newer cars it's mounted inside the cabin if memory serves me right.
Just drill a hole in the new air filter housing and move the rubber grommet and sensor over.
Old 12-20-2014 | 11:26 AM
amso3's Avatar
amso3
Ed
I noticed this a few months ago. I'm working making crankcase pressure sensor set up for 996 Cup and the intake uses the same sensor. So, it monitors vacuum. I wonder if it is use to evaluate the condition of the air filter. Just a thought
The first photo is of the crankcase pressure (vacuum) sensor and the second is of the 997.1 intake
Old 12-20-2014 | 12:00 PM
911racer's Avatar
911racer
Sounds good. I will drill a hole on the clean air side of the intake and mount it there.
Ed
Quick Reply: Changing from a 997.1 to .2 decklid
