Need 2 replacement Zircon Caliper Piston Inserts 25MM
Guys
In case you did not know, PMNA sells a retainer to hold these pucks in place when changing pads. This saves the pucks from dropping and breaking plus it is so much easier changing pads with them in place. If you don't have them you should get some. Well worth the money (I don't remember the price). I do have a few spare ceramic spacers, not sure which sizes, if you are still looking.
I think I paid about $5 each
I want to say I paid 200 per caliper rebuild kit when I did my street gt3 calipers with new Motorsport parts. These include inner seal, piston, zircon insert. Not the titanium piston setup. These are 380mm/350mm calipers same as standard 997 cup.
Former Vendor
RacingBrake has the complete caliper rebuilding components. Our Stainless steel one piece pistons are most popular replacement & upgrade to those two piece type pistons like BMW 135i, or GT-R, as they crack/separate under heat stress.
See how GT-R track guys talking about their caliper and brake upgrade:
http://www.gtrheritage.com/topic/269...r-track/page-2
Brakes upgrade for track
GT-R OE/Brembo calipers after track use:
![](http://i1208.photobucket.com/albums/cc379/wlin973/GT-Rcaliperwithtoppieceseparates_zps1d369cb0.jpg)
After rebuild with RB one piece SS pistons and high temperature (blue) boots:
![](http://i1208.photobucket.com/albums/cc379/wlin973/GT-RcaliperwithRBSSpistonandHTboots_zpsb3a4c469.jpg)
See our complete Porsche caliper rebuild components offer here:
http://www.racingbrake.com/category-s/7185.htm
Brake Caliper Rebuild Kit, Pistons, Seals, & Boots
All parts are in stock for prompt shipment.
Former Vendor
Former Vendor
BMW 135i Brembo caliper piston failure:
![](http://i16.photobucket.com/albums/b6/wleng/IMG_0570.jpg)
![](http://img.photobucket.com/albums/v694/Focusedintntions/BMW%20135/Brake%20upgrade%20kit/49d28e923ea619fbddca19eafcdb2eeb.jpg)
Replaced with RB SS pistons, Seals, Boots:
![](http://img.photobucket.com/albums/v694/Focusedintntions/BMW%20135/Brake%20upgrade%20kit/756723acc400afbc1eff598c1eb2ad11.jpg)
Original thread here:
http://www.1addicts.com/forums/showt...rebuild&page=5
Racingbrake offers a complete sizes in seal, boots (std and high heat), and stainless steel pistons from 28, 30, 32, 33 (Corvette Z06), 34, 36, 38, 40, 42, 44 and 46mm in diameter, with 30 & 32mm piston height.
Stainless steel is stiffer and stronger than aluminum alloy and transmit only about 10% of heat vs. Al.
Our pistons features thin wall cut so the weight increase over aluminum is very minimal.
![](http://i1208.photobucket.com/albums/cc379/wlin973/Piston-ThinWallCut_zps98ff61a3.jpg)
Former Vendor
Our applications may not be complete and updated as they should be due to different models/years etc.
Instead we accurately track the size and dimensions, same for pistons, seal, boots. We have most Porsche Red and Yellow calipers. So as far as we can identify your calipers we shall be able to add the rebuild kits for your Porsche.
Can you post a picture of your caliper or casting ID of the calipers?
Former Vendor
OK we did more digging and identified 996 Cup has the same calipers as 997 Turbo:
Front 6 Pot Caliper:
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4078_zps1cf3862c.jpg)
Casting No. 207907.03
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4080_zps53df6f01.jpg)
Brake Pad:
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4081_zps88784278.jpg)
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4082_zps69f828d2.jpg)
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4083_zps780a7e05.jpg)
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4084_zps77da36bc.jpg)
Replace all of those to these:
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4086_zps49dc67e2.jpg)
![](http://i1208.photobucket.com/albums/cc379/wlin973/IMG_4087_zps120657dd.jpg)
Links to the needed components in rebuilding your 996 Cup calipers:
Front (P/N BP-65) 28/32/38: http://www.racingbrake.com/Save-10-o...p/bp-65bsp.htm
Rear (P/N BP-48) 34/34: http://www.racingbrake.com/Save-10-o...p/bp-48bsp.htm
You can either purchase the complete kit: SS pistons, Seals, Boots (standard) or just seal/boot or pistons separately.
All are in stock except 38mm high temp (blue) boots which is on back order with 2-4 wks leadtime.
Brake Pad:
