FS : Blade adjustable sway bar set
Also posted in "For Sale Ads"
Front and rear blade adjustable set for 997. Will fit on rear of all "modern" Boxster, 996 and 997's as pictures show included is the RSR drop mounts.
Front installation will possibly require some modification depending on your front cross member. (997 or and RSR front cross member, no problem).
Rear bar is cockpit adjustable and front can be also with purchase of additional parts. Parts included to have rear bar non-cable operated.
This set-up has cost me over $4700.00 never installed - all is new! Everything included in photo. Shipping is not and will be based on your location.
$4000.00 or will consider offer that make sense.
It is set-up for a push/pull cable threaded at both ends,similar to a shift cable.https://www.pegasusautoracing.com/bi...asp?RecID=1071
These bars were fabricated by Mark Mathis of Mathis Engineering Group. His user name is oemexp. These are high quality pieces and if you check his posts you can get a feel for his knowledge and experience with known race teams.
