Fuel gauge, fuel cell and AIM dash question...
I have a 996 cup with a Fuelsafe cell...the cell has the sending unit for a gauge in it. My car also runs an AIM dash. Is there a way to hook up the AIM dash to the Fuelsafe sending unit? Or can I hook it up to the stock fuel gauge? Any suggestions?
Brant -- Any idea what fuel level unit you have? there is one that runs on +5V that is perfect fit for aim dash. Mine is not, I think it is a 90ohm one, but I need to check. I designed a circuit to work with it and it works well. See if you can figure out what ya have and let me know.
Rennlist Hoonigan
which cost no drachmas
Yes it can work, regardless provided a few things. If it's a resistance sender, you have to add a resistor in the wiring to make it read voltage for the dash. If it's a voltage sender, then you have to make sure it's 5 volts and then you can hook it up. Both will take making a custom sensor profile, but that isn't too hard, but will take some time.
