Need help on setup - 997 gt3 cup
Hey!
I'm new to this car, and i have driven it to times only on an airport. There is a race comming up next week. I need help on the setup.
Toe in, toe out, camber, tyre pressure, rear wing etc..
-Running the new michelin tyres
-Small racing track with max speed of 200-220
-There is some hills
I need help fast
Thank you!
I need help fast
Thank you!
Just use factory settings to start. If you have high speed push, take wing out. Low speed push add some toe in in the front. Great place to start to learn platform. Come back after event with feedback and I will try to help you tailor it to your personality, you need to start at factory setup however so you know what home base is...
997 set-up
Here is the info from the 07 Cup. I don't know the year of the car. If it is 09 or later, it is probably different info. I have the '10 manual also so let me know.
