Tall Rear Wing Uprights FS
#76
Hi,
Looking at post 25. That still appears to be the roof height uprights. Same as Post 35 (even thought that is my car and it has a large Good Aero wing) and same as RWGRIF's thumbnail (you can see it a few posts up).
Does not look like I have any pictures of cars with the mid height uprights here. Maybe someone can post one.
No, I have not made any of the mid height GT3. The roof height was been much more popular of a choice, so that is where I have been focusing efforts lately. What I have for the mid hight are the same style as shown in post 25 (which are the thicker material) and the original nuclear logo (from the stock thickness material) shown in the first post.
At this point, I could put nearly anything on a wing that you might want using the wing bodies that I have. It would just be more expensive becuase it would be a special setup charge for the laserjet cutter. (oh, and it can not be too intricate or the laser will melt the upright) And, whatever it might be I need to be able to turn it into a Autocad or DXF file.
Ed
Ed
#77
#78
Hi,
Ed
Ed
Thanks for your reply.
I was mostly interested in the style of the mid height uprights, as I suspected the pictures in the post to be of the roof height.
Can you make those as pictured in #25 in mid height, but with the GT3 lettering where you have put the small Nuclear sign? How much more will they cost if you have to swap the little sign with GT3? And is the GT3 fonts made available in another post sometime back what you need in AutoCAD to program the laserjet cutter or will something else have to be provided?
And finally, if I asked of you to make a pair of mid height uprights using the same wing bodies that you already use, but cut them like OEM ones (big GT3 cut out like in picture number 2 of OP), what would that cost.
Sorry for all the questions, and thank you for the time you have spend on answering already.
#79
The GT3 is no problem. I have that graphic already in Autocad, so it is just a matter of sizing them and having the laserjet cutter take a look at them.
It will take until the middle of the week to get back to you.
Ed
Ed
#81
OK, here is what I know. I can get them done for a $50 premium becuase I am having other uprights cut right now. Need to know quick though because they are setting up on my job now.
Either one is avaliable for the same price. I already made the cad file for either of them and sent it over.
Ed
Ed
#82
Ed
Ed
Thank you.
