996 Cup ECU read out
Got a check engine warning light after having driven in pouring rain. Car was running very fine till then and even with the light on, it ran perfect but want to see what the issue is and eventually erase that code. I have understood that you can put the car to a normal tester with a PIWIS cable but that it does not allow you to read out the engine, only the car (for example ABS)
Can someone explain me the basics on how to do a read out on my 2003 996 GT3 Cup for the main fault codes ? I'm kind of guessing but want to be sure. Do i need special software, cables etc, etc. Thanks
Look into a Durametric system. About the cheapest way to do this. The motorsport system can read the fault codes and also show you engine hours and max RPM recorded since reset.
The system is about $1k.
My racing group just got one. Not without its issues, but we are working with Durametric for a update to the version 6 software. Version 5 seems to work good.
Ed
Ed
Has anybody experienced the same, check engine light, when driving in serious rain ? Heard the 997 Cup has a drain/plug that you need to take out of the air filter housing when driving in the rain. This to prevent it from too much water being sucked into the air filter. I can't see any thing to take out of my 2003 air filter housing though ?
I do not recall what the code was when i had the light come on in heavy rain. as i recall at the time, i just reset and it did not come back.
