996 Warm up procedure
First thing in the morning, start it up for about 15 minutes, let the water come up to temp on idle, then blip it a few times, and shut it down, restart as you head to grid, restart @ 3 minute mark before run session. I run mine on the jacks in gear to warm up trans also.
Former Vendor
180+ on engine temp, if the engine temp is there the oil should be as well. On cold dys we will tape the center rad opening to sustain a minnimum engine temp of 180.
The thermostat is fully open at around 160F
We like to see this. Many people don't realize that a huge percentage of the wear on transmission components happens when it is cold and still warming up. Bringing the temp up under zero load goes a long way to longevity.
We also like to see the car run a couple times on the lift back in the shop when a new bearbox is done to bed in the gearsets.
On the GT3R I warm up it in the paddock to 160-180, then take it very easy for the first 3-4 laps of the first practice - half throttle, shift at 5k to complete the warm up and get the gearbox up to temp. Usually see steady state water temps of 210-220 with oil about 220. Seems a bit hotter than mentioned above, but I guess the RSR motor is a bit hotter ;-)
