help identifying JRZ shocks please
hey guys - can anyone tell me which of the JRZ's these are?
I'm told they're the cup 2 way adjustables but can't see any markings in the photo and they're not accessible atm.
From the JRZ website there seems to be the PROs, the PRO Race and the 2 ways but can't see the difference.
JRZ also hasn't been answering the phone Friday.
Does anyone know first hand? Also are they missing anything ...helpers or mounting plates?
TIA!!
TIA!!
@ HiWind those are single adjustable RS-Race 996 or 7 cup shocks...... On the rear shock If they are 470mm +- they are 997... 455mm+- they are 996 (overall length).. not interchangeable between the two as that would manifest itself in droop/compression over the curbs
RS-Pro is the cheaper street version with the blue anodizing and the red anodizing is the good stuff
-Tim
-Tim
if i could borrow the thread for a jrz question also. olsen motorsports can you identify these jrz setup? i cant find any kind of dampning adjustment
Those appear to be single adjustable..... are you sure that there isn't a rebound adjuster at the top of the shock? (above the jam nuts holding it in its a little 8mm brass nut).... should have 15 clicks of rebound.... and compression is fixed. Divider piston is in the bottom of the shock for the air chamber.
@ 32k Should be the same with the 8mm brass nut on the top..... Clicking it clockwise will be softer and counter-clockwise is stiffer. If I remember correctly that set should have 15 clicks. Remember its single adjustable so you are only adjusting rebound....
@ Francois i am still searching but havent seen anything yet..... I do have 2 sets of 997's here that I am trying to sell at very fair prices. Let me see how much it would cost to convert the rears to the 996 cups and I will get back to you about it..
The shaft would be expensive as everything internal needs replacing but all very possible as well as the new canisters! I will email you as there is a lot of cool stuff available for upgrades this year!
