Steering wheel buttons
What are the must have controls on your steering wheel?
I had radio only on my 996, now have radio, alarm reset, and speed limiter.
Anything else a must have?
Thanks.
Thanks.
Motec screen scroll (presuming you have Motec)
Drink dispenser
Drink dispenser
Former Vendor
Depending on how much you drive in the rain, your wiper activator, push once for 1 sweep, hold down for 1 sec to turn on. Pretty much anything that you may need to activate during a race scenario. Im sure you know first hand that taking your focus off the windscreen to make sure you are reaching for the correct button can cost you, no matter how quickly you do it!!
The controls of the 2010+ Cups aren't that bad...
-High Beam (1 short push for a flash; 1 push longer then a second for switching it on until you push the button again)
-Flashing lights (2-way-switch for left and right)
-Speed-Limiter
-Windscreen wiper (same use as the high-beam-switch)
-MoTec Button for scrolling through the dash easily
-Alarm-Reset-Button
Of course you can add also stuff like a Drink-Button or a push-to-talk but I think that those listed above are enough on a wheel of a Cup... RS R or GT3 R have more, but this is another stroy imo.
-Speed-Limiter
-Alarm-Reset-Button
OK stupid question, but are the two "blades" that mount the switches part of an aluminum piece that mounts between the hub and the steering wheel? If so is that piece available for purchase somewhere to make this easier?
Porsche Motorsport sells it. Part-No. is 997.641.583.90
Don´t know the price... Ask PMNA for it! Guess the European prices vary a bit from the ones in the US.
Then you have to go the PMNA-way.
I guess that they aren't that expensive cause it's just some aluminium or another material... Are you running the same steeringwheel as the 997 Cups (I guess it's called OMP Superturismo) ?
