FS: Motec race-grade GPS module (2), Sabelt Titan 09
Former Vendor
for sale:
as-new current model Motec Race-Grade GPS module for ADL2 dashes etc. We have two. One has a custom harness which works with at minimum the 2010 to 2012 cup cars plug and play. THere is a harness connection in the passenger footwell. We had a harness built such that you just snap into that connection point for power, can, etc. Zip tie the wires and the GPS antennae in the rear bonnet under the plexiglass, and bang, you got Motec GPS data.
There is a simple online set of instructions for setting up the GPS device in the Motec communication settings in the ADL dash manager. (we can walk you thru this by phone). it takes 5minutes and is very simple.
WIth that you can then use GPS for triggering lap times, forecasted laps, etc. You can then also build track maps with GPS points, as well as having precise track maps showing the actual track driven versus the left side or right side of track.
Some really neat features in the Motec GPS module.
New they are $950 plus $150 for the harness.
Yours for $700 shipped in the US. You should be up and running in 30 minutes.
we also then have a 2nd Race Grade GPS motec unit. This one does not have the custom harness. We had it in our camaro. its the very same main unit, antennae but we didnt build the custom connector for it. pretty simple stuff thought, a can high can low and off you go.
Same $950 for the Unit.
any questions please ask.
Yours for $600 shipped in the US
