2010 trottle body on 2007 cup
This winther I rebuild my 2007 in 2010 in all parts ( original).
I have rebuilt the engine in original 3800 parts of cup 2010 (pistons/Camshaft/Valves/etc), but not the air intake because I think it's too hard to do (and expensive because you need to change the injection/ wiring/ vacuum/ Ecu) .
The engine has good power now but I'like to fit the 3800 cup 2010 trottle body to have similar power than cup 2010.
I have foud this Plenum : http://www.ipdplenums.com/index.php?...&id=6&Itemid=9
But I'm not sure that fits on my 2007 air intake .
I know that 2007 cup has the same air intake of 2005 996 cup and I hope that 996 cup has the same air intake of 996 gt3 mk2 street car..
What do you think?
What do you think?
Ok for trottle body but I need to know if fits on. http://www.ipdplenums.com/index.php?...&id=6&Itemid=9 .
If fits it will be great , if not I have to order all 2010 air intake..
I was able to successfully machine the stock 996 plenum (which should be the same as your early 997 CUP) to match the larger throttle body (82mm at the butterfly). I wouldn't waste my money on the IPD plenum.
gret job Serge !
but in cup 2007 the trottle body and the " plenum" are in one peice ...
I need a new plenum with 4 holes to mount 2010 trottle body ( with screws )
Uploaded with ImageShack.us
The intake manifolds looks very similar to 996mk2 street cars. I don't KNOW, but I would guess that you could use either a machined 996 street car plenum or the IPD. I bet finding a 996 street car plenum + machine work would be cheaper, but that's up to you how much hassle you want to go through.
Hopefully someone here with more cup car experience can confirm.
