Modas Software guidance.
Bought the Modus Install CD and cable from PMNA. Would anyone out there be willing to share a little wisdom on installing the Modas Software? It seems a bit fussy and I can't get it to communicate.
You will need config files for your specific ecu flash as well as basic cable driver files.
What year is your car? The ecu will typically have a label with the flash number on it.
Be careful when you connect to your car as you can corrupt the hex and config file that Porsche loaded if you choose the wrong answer to a question that Modas asks on start up, after it finds the ecu.
PMNA should help you with this but if you are stuck I can give you a hand.
What I don't know yet is what the other software in the "Tool Box" is for. I just love a learning curve.....especially the driving part.
