Hoosier slick side wall separation?
I've had the same experience with 4 sets of R6's in the past couple of years on a 996 GT3. Lots of talk about this problem in the 996GT3 forum (and possibly others). Apparently due to starting with too low a pressure coupled with low ambient temperatures. Most, but not all, of my problems fit that theory, but I'm not entirely convinced.........
Congrats on the new C3 Cup. Is it easier/harder to drive than a C1 cup? More fun/less fun? I assume the suspension is a lot stiffer... and better.
I went through this EXACT issue several times when I first set up my 996 with Moton triples and the Hoosier slicks (not R6's).
Hoosier kept telling me the tires weren't inflated properly after I sent one back that separated. I reduced the rear negative camber and no more issues! The problem is too much camber!
Bob
I had a sidewall separation, somewhat longer than yours, on a Hoosier slick, RF, running my 03 cup at a DE at Mid Ohio last year. Occurred on 8th hc. Camber -4 deg 15 min. We sent the slick back to Hoosier, and to their credit they replaced it no charge. So, I presume they concluded this was a manufacturing defect.
FYI, at 16 or 17 heat cycles I experience a substantial decrease in traction.
