Porsche Cup Cars
Sponsored by: Race Cars For You
Help With Rear Plexi Crack
Old 09-12-2011 | 02:01 AM
Tim Kay's Avatar
Tim Kay
Default Help With Rear Plexi Crack
I have a crack developing in my rear plexi window. Developing from the outside edge inward toward the center, only about 3" at this point. One option I've seen is to drill a small 1/8" hole at the leading end of the crack to eliminate any further travel. Any other suggestions or is a drilled hole the best remedy?
Tim
Old 09-12-2011 | 07:20 PM
nmercier853's Avatar
nmercier853
Make sure that you use a drill bit designed for Lexan (McMaster-Carr). If you use a regular one I promise it will keep giong.
Old 09-12-2011 | 07:47 PM
jrgordonsenior's Avatar
jrgordonsenior
Tim
It works for me and I just use a regular old high speed bit.....
Quick Reply: Help With Rear Plexi Crack
