2012 Cup Cars
Here is the information we received from PMNA:
The 2012 cars will in essence remain the same with regards to tech data and we are expecting only a minor price increase. We typically receive the details for the new models from Germany no sooner than summer/early fall. In the meantime, feel free to review the 2011 Vehicle Description.
I have the PDF description of the 2011 - but I can't upload it as it is 500kb and the limit here is 147kb (c'mon - seriously?).
I have cut and pasted the pertinent info:
Vehicle Description / Technical Specifications
Details
Concept:
• Single-seated, near-standard race vehicle
• Based on the 911 GT3 RS II. Generation
Engine:
• Naturally aspirated engine
• Water-cooled flat six-cylinder boxer engine with four valves per cylinder
• 3,797 cc; stroke 76.4 mm; bore 102.7 mm diameter
• Max. power: 331 kW (450 hp) at 7,500 rpm
• Max. rpm: 8,500 rpm
• Required fuel quality: 98 octane ROZ, unleaded
• Dry-sump lubrication
• Sequential multi-point fuel injection
• Electronic engine management system MS 3.1 by Bosch
• Four-stage resonance intake manifold
• Race exhaust system with regulated race catalytic converter
• Twin-branch muffler with centered exhaust pipes
Power Train:
(Transmission)
• Six-speed sequential dog-type gearbox (G97/63) with active oil cooling and pressure-oil lubrication
• Gear ratios:
Ring & pinion gear 8/32 i = 4.000
1st gear 12/38 i = 3.167
2nd gear 15/32 i = 2.133
3rd gear 18/31 i = 1.722
4th gear 20/28 i = 1.400
5th gear 23/26 i = 1.130
6th gear 29/27 i = 0.931
• Limited slip differential 37% / 52%
• Single-mass flywheel
• Race clutch (5 ½” triple-disc sintered-metal clutch)
• Hydraulic clutch center-release mechanism
• Oil-water heat exchanger
Bodywork:
• Weight-optimized, widened body shell based on 911 GT3 RS II. generation
• Enlarged rear wheelhouses for tire size of 690 mm diameter
• Aerodynamically optimized front splitter
• Optimized ventilation for drivers through air inlet in front hood
• Carbon fiber doors with window frame and plastic rear-view mirrors
• Carbon fiber rear lid with integrated third brake light
• Carbon fiber rear wing adjustable
• Synthetic rear center compartment
• Modified, synthetic rear body panels
• Polycarbonate rear window, rear side windows and door windows
• Built-in air-jack system with pressure limitation
• Welded-in roll cage including shoulder and door bar in compliance with IMSA and Grand-Am Rolex series requirements
• Racing seat (driver side only) with fire retardant upholstery
• Six-point seat belt optimized for use with HANS system
• Removable steering wheel with quick-release coupling
• Electric fire extinguishing system with electronic release device
• 100 liter FT3 safety fuel tank system, returnless fuel with 5 bar fuel-pressure regulator
Suspension:
Front axle:
• McPherson strut-type axle, height-adjustable
• Front axle wheel suspension with twin-clamp system
• Double coil springs with race setup (main spring and helper spring)
• Sachs gas pressure shock absorbers
• Front axle control arm with six-point suspension
• Two-piece lower control arms for camber adjustment
• Longitudinal control arm
• Double-bladed-type anti-roll bar, seven-setting options per side
• Forged supporting mounts with Uniball
• Reinforced, continuously variable rear axle track rod
• Power steering with electro-hydraulic pressure feed
• Modified steering-column assembly (adjustable in height and length)
Suspension (continued):
Rear axle:
• Multilink rear suspension with solidly mounted subframe
• Suspension struts height-adjustable
• Modified wheel suspension
• Modified axle side parts
• Uniball-suspended control arm (top)
• Double-blade-type anti-roll bar, seven-setting options per side
Brake System:
Two independent brake circuits adjustable via brake-balance system and two master brake cylinders
Front axle:
• Aluminum six-piston calipers in red
• Steel brake discs (compound molding) internally vented, 380 mm diameter
• Special race brake pads without wear indicator (P50)
• Optimized ventilation routing
Rear axle:
• Aluminum four-piston calipers in red
• Steel brake discs (compound molding) internally vented, 355 mm diameter
Rims/Tires:
Front axle:
• Three-piece BBS center-lock aluminum rims 9.5J x 18 ET 37
• Michelin rain tires, size 24/64-18
Rear axle:
• Three-piece BBS center-lock aluminum rims 12J x 18 ET 30
• Michelin rain tires, size 27/68-18
Electronics:
• MoTec dashboard ADL2 with integrated data recording, 1 MB main memory
• Battery: 12 Volt, 50 Ah
• Generator: 90 A
• Error detection
• H7 main headlight and daytime running lights
• Rear lights in LED technology
Options:
• Bosch Modas interface cable and software CD: ……….. Contact our Parts Dept.
• Oil level display and sensor (recommended
for ALMS GTC):………………………………................ Contact our Parts Dept.
• Steering angle sensor:…………………………………... Contact our Parts Dept.
• PMNA highly recommends the installation of a Bosch
data recorder (with 256 Bosch memory card) to assist
with analysis of engine and transmission metrics:………Contact our Parts Dept.
• MoTec upgrade to 8 MB:……………………………….. Contact our Tech Dept.
• Brake pressure sensors:………………………………... Contact MoTec
Vehicle Weight:
Approx. 1,200 kg
Vehicle Measurements:
TBD
Color:
Water-based paint
• Exterior: Carrara white B9A
• Interior: white filler-coat, no clear-coat finish
2011 Pricing $197,000 (includes spares package); $16,000 estimated shipping
Details
Concept:
Engine:
Power Train:
(Transmission)
• Gear ratios:
Bodywork:
Suspension:
Front axle:
Rear axle:
Brake System:
Front axle:
Rear axle:
Rims/Tires:
Front axle:
Rear axle:
Electronics:
• Generator: 90 A
• Error detection
Options:
Vehicle Weight:
Approx. 1,200 kg
TBD
Color:
Water-based paint
Basic Sponsor
That is correct......new cars won't come out until 2013.
James F. Sofronas | President & Owner
Global Motorsports Group ™
E: james@gmgracing.com
P: +1 (714) 432-1582
F: +1 (714) 432-1590
A: 3210 South Shannon Street, Santa Ana, California 92704
W: gmgracing.com
W: gmgracing.com
