964/993 Cup manuals
I had been trying to find one but gave up the search. Not certain that a cup parts manual exists for the 964 as it uses mostly off the shelf parts, nothing too fancy.
Not RS. Just GT3R and RSR.
The 350mm rotors you mention - I think these were for rears, i.e. thinner like 28mm instead of 32mm or so. Furthermore they were slotted not cross-drilled. What I need to know is if there was a 350x32 cross-drilled, floating rotor.
Super Moderator
Needs More Cowbell
Needs More Cowbell
yes as stated above - 21mm spacer
1992 964 Parts list - I linked it off of the Proposed race Vehicle top menu
http://www.carreracupusa.org/964-par...rts%20list.pdf
