Porsche Cup Cars
paddle shift kit.
Old 06-29-2010, 09:44 PM
dass
dass's Avatar
Default paddle shift kit.
Has anyone fitted or know of a paddle shift kit to suit a 997 cup car.
Old 07-02-2010, 06:50 AM
Rassel
Rassel's Avatar
Look for a solution through some independent transmission specialists. But I don't know how well they work.
If you're only looking for a down-shift blip there are several other solutions that can be retrofitted on the stock gear leaver connecting it to the throttle pedal.
Old 07-02-2010, 08:26 AM
PAOLOP
PAOLOP's Avatar
I hope this can help you
http://www.youtube.com/watch?v=oUOPD3KmlIM
Paolo
Old 07-05-2010, 12:44 AM
luiscarlos
luiscarlos's Avatar
There is a company in UK that has a system for CUP cars...
Old 07-07-2010, 05:46 PM
ZSA Motorsport
Former Vendor
ZSA Motorsport's Avatar
manthey products. they build a blipper. you hit the sequential shift lever forward, it blips the throttle for you.
Old 07-07-2010, 06:46 PM
dass
dass's Avatar
I did like the idea of the full paddle shift set-up like K-M-P motorsport have on their web site ,but they a not forthcoming with infomation regards progaming ,software and how many cars are running the the same set-up.
Geartronics have done a RSR 996 ,but that is a different throttle bodies.
Old 07-07-2010, 11:13 PM
Rassel
Rassel's Avatar
There's a Manthey (first), but it requires a little cut into the gearshift stand.
There is another supplier (second) that I of course forgot the name of, but does it a little bit more neatly and cheaper, without cut.
Basically it's a little different joint design. And can be a DIY to fix it to the Manthey solution.
Quick Reply: paddle shift kit.
