Look at a late cage. Add the x behind the seats. Reinforce seat track mount area, look for cracks near engine blade mounts areas if found reinforce and weld up. Then the biggest thing, go loOk at a 997 cup and copy the cagework going from front shock towers back to front of cockpit cage. That will make a big difference. Note the factory cage is mild steel not chromoly so whoever does your welding needs to know their stuff
