My suspension setup
My suspension setup
This is my suspension setup for this weekend:
FRONT
CAMBER 4°
TOE OUT .5MM TOTAL
RIDE HEIGHT FACTORY SPEC
BAR 50%
MICHELIN BLUE 24 LBS
REAR
CAMBER 4°
TOE IN 2MM EACH SIDE
BAR 75%
MICHELIN BLUE 26 LBS
In some weeks I want to eliminate TOE front and rear to 0mm
FRONT
CAMBER 4°
TOE OUT .5MM TOTAL
BAR 50%
REAR
CAMBER 4°
BAR 75%
if you start at 20-22 you will get close to the recommended hot pressures of just under 30. Keep checking and adjusting and you'll figure it out.
that rear camber looks a bit excessive? Even the front may be a bit much, braking can suffer.
