Rules on SCCA gt 2 991.1 cup
I plan on running a 991.1 cup for an SCCA race and I was going over the rules .
Car has to be at 3,000 lbs
70 mm restrict
is there anything else I’m missing
thanks
70 mm restrict
thanks
Per Page 319 SCCA CGR May 2024
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://cdn.connectsites.net/user_files/scca/downloads/000/071/813/May-Updated.pdf?1714597295
991.1 GT3 Cup (14-16) 2dr RWD 92.7 3.8L flat six. 3000lbs. w/72mm Throttle Body Restrictor (TBR). Cars must be prepared in accordance with the appropriate model/year Porsche factory 911 GT3 Cup parts catalog/service manual. Cars may not be altered in any way except as authorized below. Drivers must have the correct year manuals as they apply to their specific car in their possession. Safety, drivers comfort, driver control and instrumentation items may be modified per the GCR. Original factory installed Matter/IMV roll cages are allowed. The stock unmodified fuel tank is allowed. Windshield clips must be installed per GCR 9.3 Windshield Clips/Rear Window Straps. All other SCCA safety standards apply. The following additional modifications are authorized: Alternate hood provided it is a facsimile of the stock part. Any wheel, including 5 bolt (and the required 5 bolt modification to the hubs). Tires per GCR 9.3 Tires. Battery size and location is unrestricted. Shocks are unrestricted but they shall be installed in the stock locations with the stock, unmodified pick up points. Any suspension settings are allowed provided they are achieved without modifications. Machining of suspension components and pick up points to achieve caster/camber/toe is not allowed. Lubricants, consumable fluids (brake fluid, coolant etc.) and oil filters are open free. Modifications listed in Grand Am, IMSA Cup, World Challenge or any other rules, except those listed above, are specifically not allowed. Factory (OEM manufacturer) Lexan front windows allowed as delivered. ABS is allowed.
Good Luck
Good Luck
Per May 2024 SCCA GCR
Good Luck
Good Luck
